d'après le question réponse:
Question: will this work on a 1995 for probe se? i bought a innova 3140 and it has the ford adapter but the 95 probe does not have the connector under or near the driverside/passenger side dash. the connector is under the hood next to the battery.
Answer: My owner's manual of the 3145 says it will work with the 4 cylinder. It does not list the v6 model. As long as it uses the EEC-IV computer system you should be fine. However It lists the v6 for other models that use the same v6 as this car. Check your ground cable also, sometimes they can be broken, and the reader won't work.
Mais je doute quand même, sinon je pense que l'info serait déjà remontée sur le forum. A voir avec l'avis des autres.
