    Voila un V6 2.0 27 Jui 2007 02:25 #60213
    KFZE c'est un moteur qui peut bien entrer dans les probes 2.0...le seul probleme...170CV!!!!!!!
    Pas mal pour monter un turbale sur ça::!!::
    cgi.ebay.com/ebaymotors/Mazda-Kf ... otohosting
    pour ce qui ont une hesitation voila les note officiels..:
    This is just a quick topic to let people know what engines will fit in their '93-'97 Probe GT, MX-6 LS, and 626 LX. This will not cover the identification of each engine, or the installation information of the engines. Though that information is readily available here on probetalk.com.
    These engines will all bolt in, fit, and work without major problems.
    Downgrades from the 2.5 V6 KLDE (the stock engine in the GT, LS, and LX)
    The K8DE - this is the 1.8 V6 engine that is OE to the North American Mazda MX-3 GS. A smaller bore copy of the KLDE, it only puts out 130hp and 115ft/lbs.
    The K8ZE - The 1.8 V6 found in the Mazda Cronos, it is a slightly more powerful version of the K8DE at 145hp and 130ft/lbs (I am not 100% sure on these numbers, but I know they are close)
    Replacement engines
    The KLDE - This is the stock 2.5 V6 found in the North American '93 - '97 Probe GT, MX-6 LS, and 626 LX. Its power output is 164hp and 160ft/lbs. If you heard that your car came with any other engine than this, you were lied to (unless the previous owner did an engine swap). If you heard that your stock power output is higher than this, you were lied to (again, unless the previous owner did an engine swap). The KLDE is interchangeable throughout the '93 - '97 model years (the DE stuck around after '97, but received many changes in '98, making it a not-so-direct swap).
    Engine upgrades
    The KFZE - The 2.0 V6 found in the Mazda Lantis. While it is technically an "upgrade", at a lower displacement and only 170 hp and 150ft/lbs, it is hardly worth the trouble in swapping in. But if your just looking for a low mileage replacement engine, this may be a good bet, as they go for around $400 online.
    The KLZE - This is really the only true/beneficial engine swap upgrade for our cars. It is a 2.5 V6, found in a few Japan marketed Mazda cars, it boasts 190 - 197hp (dependant of year), and 160ft/lbs. Essentially the same as the stock KLDE, getting it's higher power output thanks to slightly more aggressive cams, higher compression pistons (10.0:1 compared to the DE's 9.2:1), better flowing intake manifold and heads, and a slightly more performance oriented ECU.
    All of these engines look VERY similar to each other, with subtle differences giving away their model designation, so be sure to do your research before purchasing.
    If anyone has any correction (with proof) to the information I have provided, please PM or IM me so I can change it. This is just a quick topic to let people know what engines will fit in their '93-'97 Probe GT, MX-6 LS, and 626 LX. This will not cover the identification of each engine, or the installation information of the engines. Though that information is readily available here on probetalk.com.
    Replacement engines
    Engine upgrades
    Re: Voila un V6 2.0 27 Jui 2007 06:40 #60215
    :?: le seul probl?me est :qu'ils ne livrent pas en dehors des US
    :roll: :roll:
    Re: Voila un V6 2.0 27 Jui 2007 09:39 #60220
    poulain écrit: :?: le seul probl?me est :qu'ils ne livrent pas en dehors des US
    :roll: :roll:
    hmmm tu sais TOUT est negociable...
    Re: Voila un V6 2.0 27 Jui 2007 10:45 #60224
    Aucun interet ! vu que le boulot d'adaption sera le meme pour un KLZE qu'un KFZE autant prendre le KLZE ... :lol: et surtout autant acheter un v6 ;)
    Ne pas oublier qu'il faut changer ? la louche :
    support moteur
    boite
    faisceau
    pcm
    tout les accessoires ou presque (allumeur, alternateur, clim ... )
    Re: Voila un V6 2.0 27 Jui 2007 17:29 #60255
    pas de clim JF, c'est trop lourd :p
    Re: Voila un V6 2.0 27 Jui 2007 17:33 #60256
    merde grillé :roll:
    Re: Voila un V6 2.0 27 Jui 2007 17:36 #60258
    vu qu'on est ds bon plan, tu as un bon plan pr qu'un probiste me vende sa 300zx jaune JF ??? comment lui demandé, pr qu'il accepte :roll:
    Re: Voila un V6 2.0 27 Jui 2007 17:42 #60261
    A 20 000? elle part ;)
    Re: Voila un V6 2.0 27 Jui 2007 17:45 #60263
    JF16v écrit: A 20 000? elle part ;)
    tu diras au gars qu'il se touche un peu :lol: :lol: a 20 000 j'prend mieu
    Re: Voila un V6 2.0 27 Jui 2007 17:54 #60265
    Prob'snake écrit:
    :content:
    Nous avons 223 invités et aucun membre en ligne
